05 road king Transmission Shifter Shaft Assembly
i am to the point where i need tools. pulley holder $100, race bearing puller $200+, the race bearing walked, so i need a separator $50+. still haven't got all the parts needed, gaskets, seals, bolts, lock washers and so on. did get the shifter pawl from harley $102. willing to bet its not the right one, for what ever reason comes up. anyway, probably wont have update for awhile.
RRHODSS (10-30-2021)
Lock the tranny to remove front sprocket
Since this post is here, riddle me this?
05 FLHRCI
Replacing the inner seal on the front (sorocket) shaft.
I have pulled inner an outer primary,
and pulled of top of tranny inspection.
need to know how to lock tranny to remove sprocket nut.
My ho-made socket not as sweet...
05 FLHRCI
google
05 FLHRCI
05 FLHRCI
my google words "how to lock harley tranny to remove front sprocket"
Heaps of u tube solutions.
Dont forget before you use the impact gun. Left hand thread.
RRHODSS (11-29-2021)
bouncing betty
05 FLHRCI
05 FLHRCI
i am told that its possible to put two gears together to hold shaft. i will be putting two gears together to loosen nut on main output shaft (right side of tranny). what two gears, i do not know yet.
i like the home made socket you made. i am getting ready to paint my buddy's socket.
buddy just ordered the cheap race puller online. should be here in a week. will have pics soon.
Sorry been a minute.
I touched base with my indy. He had a replacement shaft for 35$. So I cut the old shaft off about where I thought the threads ended. Drilled a small hole to help get heat on the shaft.
Welded the bolt back together, applied a lil heat from a heat gun and my Sears rattle gun spun it off.
Thanks for your inputs
stoneybagger (11-27-2021)
not alot, we have winter. its not much though.
pretty sure it the grease for the clutch cable.
Last edited by stoneybagger; 11-29-2021 at 05:09 PM. Reason: got me!! would be nice to have a edit button that does not go away.
RRHODSS (12-10-2021)
