Intermittent Ignition Switch
Hi all,
I've got a 2007 Street Glide that has started having an issue where if I barely bump/wiggle the ignition switch the power will cut out.
I first noticed this a couple of days ago when I started the bike and it just died. Now, whether it's running or not I can barely move the switch and it will lose power.
Any help would be greatly appreciated!
I suggest flushing the switch through with some WD40 or similar, to clean out any muck that may be in there. I've occasionally had similar problems with bikes in the past. Once flushed through and if the switch seems to work better, I would add a little grease, to lubricate the innards. By all means check the wiring connections to it and, if all else fails, simply replace it.
I'd still go ahead and replace the switch. They're not that expensive and you know you won't be left stranded somewhere.
