My Ohlins experience
I recently purchased and installed a set of #3-3 Ohlins on my Ultra and the difference is all in the ride. Now it did not come as easily as I had hoped, but by no means was it hard to do. After talking to Howard and following his advice we came to the conclusion that I needed a heavier spring set. Howard sent me another set of springs quickly and I changed them out with no problem. Went back to the first steps of install, setting sag, using the zip tie, road testing, etc., and after almost 500 miles on the shocks about all I need to do is dial them in a little more and ride. I found Howard to be a wealth of knowledge and if you truly listen to the man he will help you get your shocks set properly. Now I know just how lacking the front suspension is and that is on my to do list.
The following 2 users liked this post by JonnyVegas:
Bluemax2 (12-30-2020),
Fireball Jack (12-30-2020)
While I realize this is originally a 4 year old thread...I agree.
On my 05 with Howard's Ohlins out back and progressive mono tubes up front, I set the sag and rode on.
On my 19 limited, it was much, much more finicky about sag settings. I swapped the shocks over and put Axeo cartridges up front.
It was a bucking bronco at first. Once I dialed in the rears...the front smoothed itself out. For me, I run a hair more sag then recommended and turn up the compression a few clicks.
I have one sag setting for solo, then crank them up 4 turns for 2 up with my wife. It did take some time to figure out the right setting for us... but once you get there, the light bulb goes on big time.
Eccool (01-20-2021)
Phone #: 1-954-848-1525
~Contact via e-Mail~
use my own e-Mail: howard@motorcyclemetal.com
http://www.motorcyclemetal.com/contact.html
