Is there a fix for FM radio loss with a class D amp??
Old 05-03-2016, 07:14 PM
Porgey's Avatar
Porgey
Porgey is offline
Default Is there a fix for FM radio loss with a class D amp??
I know this one has been beat to death....I have looked at i think every post here on the topic...I have a 2015 street glide and have the big boom radio....I have the amp on top where it can go and yes its a class D amp...Did have H/D power hidden antenna its gone now tried a J&M flexpower antenna NO help its gone now I have put factory antenna back on NO help...I took 8ga. power-ground and twist them from batt. to radio...also twisted both speaker wire all the way...maybe gained 1 station back....I understand the RF signal messes with AM/FM signal....Sooooo is there a shield of some kind to use??? OR is there no answer to this other than a class H amp i,m told by the amp tech. support? JUST ASKING THANKS
Old 05-03-2016, 07:21 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
hmm- I'd reposition the amp- throw it in a saddlebag.
'quality' electronic goods should be CE certified and not radiate RF unless something is broken
Mike
Old 05-03-2016, 08:32 PM
Budda109's Avatar
Budda109
Budda109 is offline
I have the RZ D2000 amp. Had the same issue. Also was helping a friend. Found an answer that worked for us both. Used some copper tape. Do a Google search. Blocks EMI. "Electro magnetic interference" . I bought some 1/2 inch about 3 FT. Also some 3i nch by 10 feet. Both were about $10 total from Ebay. Also saw some at Homedepo. I wrapped the antennae wire. As far back as possible from the radio. Also layered the top of HU. I now have excellent reception. My buddy is going to try it this week. It should work for him. I gave him what I had left. Should be enough. Tape has the consistency of aluminum foil. I used the wide stuff and cut strips. Good luck
Knucklebuster27 (10-22-2020)
Old 05-03-2016, 09:50 PM
RatPwrd72's Avatar
RatPwrd72
RatPwrd72 is offline
Satellite radio fixed mine.
Old 08-17-2019, 11:24 PM
Dougsteph10's Avatar
Dougsteph10
Dougsteph10 is offline
You can build a Faraday cage. Just wrap it in copper window screen
Old 08-18-2019, 06:18 AM
HDFRENZY's Avatar
HDFRENZY
HDFRENZY is offline
Stream.
Old 08-18-2019, 06:38 AM
Dsm Limited's Avatar
Dsm Limited
Dsm Limited is offline
Received 9,592 Likes on 3,245 Posts
Change the amp to one of several others.
Arc 600.4
Stinger 700
JL 600.6
SD 800.4
Mmats 4110
Some amps just kill FM, others not as bad. Fairing antennas and amps don't play well together.
Old 08-18-2019, 08:00 AM
GalvTexGuy's Avatar
GalvTexGuy
GalvTexGuy is offline
Received 4,241 Likes on 2,322 Posts
What's FM radio?
Old 08-18-2019, 08:59 AM
FPV's Avatar
FPV
FPV is offline
Originally Posted by GalvTexGuy
What's FM radio?
A Podcast from Fuel Moto, maybe???????
GalvTexGuy (08-18-2019)
Old 08-18-2019, 09:03 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 9,473 Likes on 5,052 Posts
FM radio has sucked ever since two companies bought all the stations.
Sorry, can`t help with any advice on a motorcycle mounted radio, never had one....
Quick Reply: Is there a fix for FM radio loss with a class D amp??
