Notices
CVO air cleaner/ Screamin Eagle Ventilator
Old 04-30-2016, 11:53 PM
head's Avatar
head
head is offline
Default CVO air cleaner/ Screamin Eagle Ventilator
Have a 2008 CVO air cleaner on the way. It's missing the center oval insert. Any idea if the ones off of the Screamin Eagle Ventilator air cleaners are the same? They sure look like it. The inserts are the ones that require two fasteners to attach it to the air cleaner cover. Here is the air cleaner that I purchased. Thanks..
Head
Attached Thumbnails CVO air cleaner/ Screamin Eagle Ventilator-ac51.jpg
Old 05-01-2016, 04:07 PM
mjonesjr84's Avatar
mjonesjr84
mjonesjr84 is offline
Attached is a couple pictures of measurements of mine Ventilator A/C on my '08 to give you an idea the size of the Ventilators cover.
Here is one just like mine that is NOS on eBay going for $20 right now.
http://www.ebay.com/itm/391445435644...%3AMEBIDX%3AIT
Attached Thumbnails CVO air cleaner/ Screamin Eagle Ventilator-img_20160501_170150.jpg   CVO air cleaner/ Screamin Eagle Ventilator-img_20160501_170200.jpg   CVO air cleaner/ Screamin Eagle Ventilator-img_20160501_170220.jpg
head (05-01-2016)
Old 05-01-2016, 06:22 PM
head's Avatar
head
head is offline
Thanks for taking the time to measure that for me. Much appreciated! My cover should be here in a few days and I can measure what I have then and get something coming. Hoping that they are the same.
Head
Old 05-01-2016, 09:42 PM
beasleyiv's Avatar
beasleyiv
beasleyiv is offline
They are the same.
head (05-01-2016)
Old 05-01-2016, 09:48 PM
head's Avatar
head
head is offline
Thanks.
Head
Old 05-01-2016, 09:54 PM
skratch's Avatar
skratch
skratch is offline
Received 4,323 Likes on 2,522 Posts
the insert for the 2016 cvo ventilator doesn't have the eagle head, but does say screamin eagle and is only $10.00
pn 14100699
head (05-01-2016)
Old 05-01-2016, 11:45 PM
beasleyiv's Avatar
beasleyiv
pn 14100699
And that one is totally different than the previous Ventilator cover. I have all of them. I like the 2016 CVO cover better, so I switched to that. I have the previous cover and have both the SE eagle and the 110" medallion that works in the up-to-2015 CVO and non-CVO ventilators. The air cleaners are the same in pre-2016, just a different 110" medallion went on the CVOs.
Old Style:
New Style:
The bolt locations may be the same (I never bothered to check) but the new medallion would look a bit odd on the old cover since it's so much smaller. But to each his own...
head (05-02-2016)
Old 05-02-2016, 05:53 AM
mjonesjr84's Avatar
mjonesjr84
New Style:
You wouldn't happen to have the part # for the new cover and SE insert? I do like the new cover better than the old style I have currently.
Old 05-02-2016, 06:00 AM
beasleyiv's Avatar
beasleyiv
Last two line items. *edited to remove pricing just in case that violates some rule.
head (05-02-2016)
Old 05-02-2016, 06:01 AM
mjonesjr84's Avatar
mjonesjr84
Last two line items. far right column is Ronnies discount pricing, check with Boardtracker too.
Thanks!
Quick Reply: CVO air cleaner/ Screamin Eagle Ventilator
