Oil coolers
Old 04-26-2016 | 10:58 AM
bigheadted's Avatar
bigheadted
Originally Posted by ULTRA ZOOM
I just checked out the Jagg cooler with the fan. Wow it was $550 and they use rubber hose with hose clamps. So I like the Ultra cool better, braided lines and its like $ 400. So I guess I will order one.They are made in Hollister Calif.
Originally Posted by xcbullet
It just turns on fans
So a made in china product without a thermostat BUT it has braided lines for 150 bucks less ??
Save your money and get top shelf known quality from a company that supports your country by making their product in the USA.
Clamp on rubber lines have neen in use for many years and there is not a thing wrong with them, if you get quality made in the USA ones.
Your bike your money ride safe
Old 04-26-2016 | 11:20 AM
xcbullet's Avatar
xcbullet
Not sure if the jagg has thermostat either, I think only Harley does.
Old 04-26-2016 | 11:24 AM
bigheadted's Avatar
bigheadted
Old 04-26-2016 | 11:28 AM
xcbullet's Avatar
xcbullet
All I'm seeing is a switch for the fans just like the ultra.
Old 04-26-2016 | 11:34 AM
bigheadted's Avatar
bigheadted
keep reading dont stop when you see what you want. Says thermostatically controlled adaptor. Give them a call like I did when I was looking at them a few years ago. Ended up not needing one .....yet.
Install a oil temp gauge and you might be shocked at actual oil temps. Moving below 20mph on above 100 degree days or stopped is about the only time oil got hot enough to be concerned on my tiny 88 incher.
Old 04-26-2016 | 11:43 AM
xcbullet's Avatar
xcbullet
Read PDF they call it a switch.
Old 04-26-2016 | 12:09 PM
Deckman's Avatar
Deckman
I just installed a Jagg w/o fan on my Street Glide and it has a Thermostat that opens when the oil reaches 210 degree F. It works OK until sitting in traffic here in Charlotte, then bike still gets hot. Definitely not as hot without the cooler, but only 10 degrees cooler. If I had to do it again I might have gone with the Oil Bud cooler, a lot more surface area to cool the oil.
Old 04-26-2016 | 12:15 PM
bigheadted's Avatar
bigheadted
I just called and spoke with them and as i thought it does indeed have a thermostat to control oil flow and a switch for the fans.
Nice folks and always friendly and actually KNOW their product. Like BAKER and the other top shelf guys.
So for 150 more dollars you get USA and all you need but you get rubber lines !!!
No brainer Maynard !!! hahaha
Old 04-26-2016 | 12:17 PM
qtrracer's Avatar
qtrracer
99% of all steel braided lines used to carry oil are rubber. Total waste of money and unless you get vinyl covered they will eat paint and wiring.
Old 04-27-2016 | 01:36 AM
mcain49's Avatar
mcain49
I have the JAGG 10 row w/o t-stat. Works well and installation is fairly straight forward. The anti-rotation device is extra ($10 I think) but worth it.
Quick Reply: Oil coolers
