Do I have a fuel flow or engine problem?
Do I have a fuel flow or engine problem? *RESOLVED (post #10)
2002 fuel injected Road King.
Rode about 100 miles yesterday, no problems. Btw, I checked the oil before yesterdays ride - all good.
Today I'm out riding and the bike sputters bad, think I might be out of gas...limp into station. Bike only takes 3.5 gallons.
Listen to fuel pump, it primes and stops (no run on). Figuring it's a fuel flow issue and I'm pretty much out of options for getting it the 7 miles home I decide to go for it...
I can keep it running by working the throttle and keeping the revs up but it sputters and backfires...occasionally i get a good run...and then back to sputtering and backfiring.
Get home, pull in garage and realize its kinda smoking...and seems really hot.
I checked for codes...no codes.
Now I'm just drinking a beer and feeling bummed...anyone got any thoughts?
+1 for checking the fuel filter.
I have a '00 fuel injected Road King. At about 60k miles it began to bog down and not rev much past 3,500 rpm before it would sputter and stall. It had had a dealer-performed 50k service, which the checklist said included the fuel filter being replaced. After having the dealership look at the stalling issue and tell me they couldn't find anything, I decided to check the fuel filter myself. Changing the filter isn't hard, it is just a PITA to get to it. I replaced the filter, and while in there replaced the in-tank fuel lines. Now the engine pops off on the first press of the starter, and freely revs up to (and beyond) the redline.
BTW, I haven't spent another nickel on service at this dealership in 3 years now.
Thanks for additional input.
Question, how do I check for codes on an 02 with a Delphi? Do I use the shorting of the data link connector method or the odometer method? I've searched for a difinitive answer but I'm still confused.
Btw, I tried the odometer method yesterday and it showed no codes...but now I'm thinking I might be doing it wrong for my year/model.
Update with resolution...
Well after 17 days in the shop, I picked her up yesterday...boy was I glad to have 'er back. So as it turns out post #2 (klc997) had it right - fuel pressure regulator. As much as I wanted to troubleshoot and do the work, in the end I just didn't have the time or skills to do it myself.
I ended up replacing the fuel lines, fuel regulator, and fuel filter. I also had to buy a new battery. All totaled it cost me $550 bucks - I'm ok with that.
Thanks to everyone who offered up suggestions, maybe someone can learn from this experience.
