Anyone running the GENSSI LED passing lamps???
Picked up a set of these to match my JW Speaker Evo2 headlight.
Anyone have these?? If so how do you know what position to mount them. There are no markings to tell if they are left, right, up or down. Looking at them installed I can't really see a difference between the two on or off. Is there a correct position or doesn't it matter.
Hello
I purchased the Genssi passing lights for my ultra. I did drill a 3/8 hole and installed a rubber grommet on the inside lower corner of the passing light housing to accommodate the wires.
They are exceptional so far.
I did have a bit of a problem aiming the lights. The Genssi LED lights have no top or bottom. If you cant get them to line up. reverse one of the lights and that should take care of the problem. They do have a top or bottom it is just not marked. Only had them for a couple of weeks but for the money I am very impressed. very well built. Hope this helps.
Talldog
06-11-2014 08:46 AM
