Which V&H muffler is closest to Rineharts?
04-13-2016, 07:26 PM
I just order a FP3 from Hogpro.. I'm going to give it a try on my Cam'd 14' Street glide special. I'm wondering if anyone knows which V&H is most similar in performance/design to my 4" Rineharts so i can try to pick the right base map.
04-13-2016, 08:02 PM
None.
Matter of fact, V&H sound like a 'soda can' with a little packing in it.
You need Rush, Rinehart or another quality slip on.
04-13-2016, 08:19 PM
Quote:
Originally Posted by
not a sock
None.
You need to read & understand what the OP wrote & meant.
04-13-2016, 08:23 PM
SGMongoose, Call V & H. They will recommend which map to choose. I'm betting it will be the Twin Slash Round or Monster Rounds. I have one friend that found the Hi Output map worked well with his Rineharts. Plus, you will be able to autotune.
04-13-2016, 08:33 PM
I used the base map for the V&H 4" slip ons and then put it in autotune mode. It worked fine.
04-13-2016, 09:01 PM
I would say Twin Slash Rounds only because the Rhineharts are straight through like the TSR's are, jmo! I have Monster Rounds on mine and they are not straght through pipes, there is a baffle of sorts in the Monsters Rounds.
04-13-2016, 09:07 PM
Awesome, thanks for the advise guys! A little nervous about how the FP3 is going to work with the cams so want to get as good a base map as i can.
04-13-2016, 09:10 PM
not a sock
None.
Sounds like the OP runs Rineharts
04-13-2016, 09:19 PM
Contact V&H and tell them slipons and cams you are running. They should recommend a base map to auto tune.
04-14-2016, 07:44 AM
not a sock
None.
All the knowledge in the world.......
Timberwolf7707
04-01-2019 06:11 PM
firehawk6
08-22-2017 08:57 AM
brainchill
Vance & Hines
07-29-2017 08:41 PM
BROWN616
06-25-2016 05:55 AM
flhxs103
06-05-2014 04:19 PM
