11 street glide aftermarket radio install
Old 04-13-2016 | 03:25 PM
cbauer1987's Avatar
cbauer1987
Stage I
Default 11 street glide aftermarket radio install
hello everyone,
i am new to the forum and would like to try and start out with a easy question.
what will be required to install a aftermarket kenwood cd player??
i would like to also keep the factory handlebar controls in working function with the kenwood cd player..
i will also installing a Rockford Fosgate PBR300X4 amp &&Kuryakyn Kicker Tweeter Dash Pods && a set of Hertz MPX-165 6.5" front speakers
please keep in mind over the winter i will be adding 2 rear speakers in the saddle bag lids
Old 04-13-2016 | 04:40 PM
Wander's Avatar
Wander
There's some videos on YouTube that will walk you through the process.
Remember to run both Power and Ground to the battery from the amp.
Getting the radio mounting bolts out is a bit of a PITA, made much easier with a long arm hex with a ball end.
Old 04-13-2016 | 06:11 PM
otto76689's Avatar
otto76689
The Mille Pros didnt fit in my sreet glide.. didnt feel like cutting up the 6.5" adapters and making a spacer plate out of ABS plastic..My buddy owns a custom car/motorcycle stereo shop and the are a hertz/audison dealer. It takes a bit of work to get them to fit and they are a very power hungry speaker (always better to overpower a speaker than under power them, under powering causes excessive heat in the voicecoil). I went with the Audison Voce 6.5" speakers and they definitely slam i have 290W rms x 2 running to them and i wouldnt change a thing..just my 2 cents
Old 04-13-2016 | 06:43 PM
kishstl's Avatar
kishstl
Head over to the audio systems forum. TONS of really great info there and guys who install for a living. Great source of info for me when I upgraded my 11 SG
Old 04-14-2016 | 12:15 PM
Dguy's Avatar
Dguy
You already are on your way as far as components go.....just pick this up and you're done. Biketronics are expensive but a quality product and their customer service is second to no one. This kit gives you the faceplate, handlebar control adapter, radio mounts etc. This is all you need. BT1005x
Attached Thumbnails 11 street glide aftermarket radio install-bt1005x_low__58720.1454014838.1280.1280.jpg
Old 04-14-2016 | 12:18 PM
Frank Dukes's Avatar
Frank Dukes
this. just did mine over the winter. worked great and super easy to install.
Old 04-14-2016 | 12:19 PM
Dguy's Avatar
Dguy
I have this kit on mine (2 yrs now) and works perfect. I went Kenwood as well. Great Unit!
Old 04-14-2016 | 01:35 PM
DamifIknow's Avatar
DamifIknow
I had Biketronics on my 06 with a Sony head with CD and USB and it worked great.
NC_RIDER
Audio Systems
08-19-2016 01:43 PM
whynotf75
Audio Systems
02-17-2015 07:11 AM
FLYINGBROKE
Audio Systems
09-17-2014 06:20 PM
BrianCash
Audio Systems
02-16-2014 07:07 PM
rhd01
05-01-2012 08:09 AM
Quick Reply: 11 street glide aftermarket radio install
