Hd premium adjustable shocks used on pre-09
Old 04-13-2016 | 09:37 AM
rtm1980's Avatar
rtm1980
Default Hd premium adjustable shocks used on pre-09
Sorry if this is an old topic or if there is already a thread, could not find any. I am looking for responses from riders who have ACTUALLY been running the new adjustable shocks for 09-newer bikes on a pre-09 frame and if you have had any issues. Looking to install on my FLHTCSE2 CVO Electra Glide, thanks.
Old 04-13-2016 | 11:33 AM
mkguitar's Avatar
mkguitar
the current shocks can be run on bikes back to the 1983 FLT.
the change to the shocks in 2009 wasn;t a physical fit/mount is was a change to the valving in the shock internals.
the length of the shocks and the shock travel was unchanged- 13"/2.75"
the 09 has a higher weight carrying capacity, the shocks were altered to deal with that and "for better rider comfort"...
Mike
Old 04-13-2016 | 11:38 AM
lt1-xjs's Avatar
lt1-xjs
I have them on my 2002, there are a few running them without issue. Below 2002 might be an issue. I have the 12" version, a little firm.
Old 04-13-2016 | 12:00 PM
rtm1980's Avatar
rtm1980
I am more concerned with stress or twisting of swingarm.
Old 04-13-2016 | 03:53 PM
lt1-xjs's Avatar
lt1-xjs
I don't notice anything, a twisting swing arm would be noticed.
Old 04-13-2016 | 10:13 PM
Bumpandrun's Avatar
Bumpandrun
No problems at all as long as you have the 02 -08 swing arm. Older than that look at them wrong they crack. But shocks won't matter. They do ride well for cheap money
Old 04-13-2016 | 10:26 PM
SafetyMan's Avatar
SafetyMan
The pre-09 swingarm was not as strong, not designed for the style shocks you are talking about.
There are many who have done it, and haven't yet seen an issue.
Personally, I wouldn't do it.
Old 04-14-2016 | 01:06 PM
grbrown's Avatar
grbrown
Those shocks have a different spring rate on each side, also different damping each side. That is why the '09 and later models have a stiffer swingarm, to minimise any affects of each side of the swingarm being under different loads.
JHC210
Milwaukee Eight (M8)
20
07-20-2020 11:42 PM
mdanehart
02-19-2019 12:47 PM
chgofirefighter
09-09-2013 05:03 PM
EZSkankin29
Screamin Eagle CVO Models
14
03-12-2013 07:58 PM
DanDman
01-27-2013 03:30 AM
Quick Reply: Hd premium adjustable shocks used on pre-09
