Stealership Probs
RE: Stealership Probs
The problem with the neutral light is the neutral switch. The Motor company issued a bulletin and new switch in March. That will fix your neutral light. Part number is 33926-02B. The dealermight not be full of #*%. You need to look at the interface area all the way around. On the 07's they have an aluminum gasket that seperates the feed and return lines. All of the 07's I have seen that had leaks were only on top. Oil doesn't flow up. There was no oil on the bottom of that interface or near the gasket surface. We have done two in 07 because the customer said like most here, we didn't know what we were talkin about only to realize the cases were dry in between the interaface. check the bottom. And call the MOCO or any othermanufacture with cast aluminum blocks and "weeping" is a normal occurance. Should have stuck with the black cases.
