Harmon kardin radio cuts out while not running
Old 04-11-2016, 04:26 AM
Luke Gasper's Avatar
Luke Gasper
Luke Gasper is offline
Stage III
Default Harmon kardin radio cuts out while not running
My HK radio cuts out all the bike is not running. It only seems to do it at higher volumes. All speakers have been replaced with hog tunes, a hog tunes tweeter pod added, and amp. It also cuts out while the bike is running.
Old 04-11-2016, 06:46 AM
rusty289's Avatar
rusty289
rusty289 is offline
What year is your bike?
Old 04-11-2016, 06:54 AM
Luke Gasper
Stage III
It's a 2008 ultra classic
Old 04-11-2016, 07:05 AM
rusty289's Avatar
rusty289
rusty289 is offline
I can't remember if the 08s had it but 09s for sure had a recall or service bulletin on the handlebar riser bolts. There was not enough clearance between the head of the bolt and the body of the radio. This would cause the radio body to contact the bolts while riding and eventually it would damage the radio to the point it would stop working altogether or work intermittently. With mine it looked as though everything was working, radio was on and would show as if it were playing I just had no sound, happened on a long road trip too which really sucked! That's what happened to me and it was not covered by warranty, I had to send my radio away to have it fixed. I used Iron Cross Audio, awesome company to deal with and very fast turnaround, they had the radio on the way back to me maybe 2 days after they received it.
http://www.ironcrossaudio.com/
Old 04-11-2016, 07:40 AM
Luke Gasper
Stage III
I believe it was the 09 that had the service bulletin on the riser bolts. I plugged in a known good HK radio and it does the same thing. It does it if just the ignition switch is on and if it's running. But only seems to do it at higher volume
Old 04-11-2016, 07:54 AM
NascarGuy's Avatar
NascarGuy
NascarGuy is offline
http://www.ironcrossaudio.com/contact.html
Give them a call. They'll fix you up. Excellent customer service
Old 04-11-2016, 08:01 AM
rusty289's Avatar
rusty289
rusty289 is offline
You said you had an amp too right? Could the amp be cutting out on safety? Over heating perhaps or just drawing too much current?
Are you still running the 2 ohm speakers? I believe stock HD speakers are 2 ohm and a lot of the replacement/upgrade kits will stick with the 2 ohm to maintian volume levels. Lower resistance speakers are louder but will draw more current, maybe the amp can't handle it?
Hog tunes stuff though should really work properly I would think.
Old 04-11-2016, 10:25 AM
hdbob2006's Avatar
hdbob2006
hdbob2006 is offline
I have the same lousy amp & speakers. Mine were cutting out while riding though. And it seemed like higher volume caused it to cut out a lot faster. The instructions for the amp say to set your AVC to 3 bars. I set mine on 2 bars last summer,and it has never cut out since then.
Either that fixed it,or I fixed it when I had the fairing off and twisted and pulled all the speaker wires around,looking for something loose...
Old 04-11-2016, 11:18 AM
rusty289's Avatar
rusty289
rusty289 is offline
YEp sure sounds like the amp is overlaoding based on that info.
If the AVC is up too high that can really stress the amp out at speed, it's cranking up the volume automatically causing the amp to crank up the output.
My suggestion is to turn off AVC altogether.
Old 04-11-2016, 12:33 PM
Geoff's Avatar
Geoff
Geoff is offline
My '06 Ultra had a similar problem with the stereo cutting out. I discovered three things.
First, one end of a crossover resistor on the right front speaker was loose. I soldered the resistor.
Second, my bike has a Hogtunes amp. The amp's slide switch for 2- or 4-channel operation was positioned halfway between settings. I set the switch to 2-channel. (I think was the main culprit.)
Third, when I ran a diagnostic using the radio's built-in feature, the results showed an open right rear speaker. The speaker worked, but sound was faint. I swapped the right/left rear speakers to confirm the defect; then I replaced the bad speaker.
After I completed these fixes, the stereo stopped cutting out.
rusty289 (04-11-2016)
Quick Reply: Harmon kardin radio cuts out while not running
