2005 Electra Glide Classic
Okay so I was reading one of the other forums and while I was reading it got hijacked by another post and actually had the question that I was asking but it never got answered so here goes. We replaced the cam tensioners and the bike turned over and started but now it acts like it doesn't even want to have any power to the fuel pump. My check engine light comes on and stays on but sometimes it goes off and flickers and comes back on. I'm not sure if it is a crank sensor or a pinched wire I kinda need a lot of help here. As it is getting really warm outside and I'm ready to ride my bike
Did you remove the fuel tank and go down through the rockers to change out the tensioners or did you cut the pushrods and go with adjustables? If you cut the pushrods and just changed out the tensioners, the fuel pump wouldn't necessarily be affected. As for engine light, check the codes to see what they are and go from there.
joebotics
11-29-2012 05:33 PM
