Cams + 107 v Cams + heads....?
Old 04-07-2016, 09:02 AM
gipper's Avatar
gipper
gipper is offline
OP: If I were you, I'd now silence ALL these little voices in your head, and pick up the phone and call both Scott at Hillside, and Jaime at Fuel Moto. Explain that you're on a budget and looking for the biggest bang out of your buck. Talk to them both, and then make your decision. They're both good.
Scott has already chimed in, and I suspect that you'll feel even better after talking with him on the phone.
hattitude (04-07-2016)
Old 04-07-2016, 09:45 AM
hattitude's Avatar
hattitude
hattitude is offline
Received 8,190 Likes on 4,398 Posts
Thanks for all the input/insight...... a lot to digest ....
Sounds like heads and a cam can get me where I want to go, time to make a few phone calls...
Thanks again....
Old 04-07-2016, 10:31 AM
Scooterbear's Avatar
Scooterbear
Scooterbear is offline
I did the TW-555 Cam, and FM Level B Heads on my 103 this past winter due to excessive carbon build up on heads/pistons at 11,000 miles. Figured since I had to tear it down to clear out the carbon I might as well rebuild the top end.
I'm really happy with the results so far and wouldn't do a 107 until the cylinder wear is enough to warrant it.
The carbon build up was caused by the HD Stage 1 AC sucking in the crankcase oil. So along with the head work I also did the breather bypass, installed the Rocker Lockers, and replaced piston/rings since the cost was reasonable versus grinding carbon. Honed the cylinders and have zero oil usage and zero getting in the intake.
I recently installed Wards Fan to eliminate high head temps in stop/go traffic. Works great so far.
Old 04-07-2016, 01:13 PM
GEORGEW's Avatar
GEORGEW
GEORGEW is offline
I have a 2012 FLHTK, TC103, stage II (SE255 cams, Jackpot 2/1/2 ceramic headpipe,SE A/C, SE Slip-on mufflers). I will eventually end up with a Fuelmoto 107 kit and level "B" heads..... Problem is, I won't be able to buy it all at once.... I'll be doing the work myself.
I plan on using the TW-555 cams.
I can afford one of the following at the same time:
Level "B" CNC heads
107 big bore kit
It would be easiest financially to do the heads/cams this year, and then next year do the big bore kit.... but I can pull it off either way...
My question... which combo will I feel the biggest change, when done together-- Cams & heads or Cams & 107 kit...???
I actually had a friend say that with my 103, cams & headwork, I may not want to go 107.... not sure I buy that..
Thanks in advance for your insight/experience...
Two Questions
1.What Exhaust System are you Running?
2.What are you using for a Tuner?
3.What RPM Range do you Spend Most of Your Time?
4.Are you looking for Low-Mid or Mid-High Power?
Old 04-07-2016, 09:01 PM
hattitude's Avatar
hattitude
Originally Posted by GEORGEW
Two Questions
That's four questions, but who's counting....
1. I have a Fuelmoto Jackpot 2/1/2 head pipe with SE slip-on mufflers
2. I have a PowerVision and the Auto tune 110 pro
3. I ride mostly 2-up cruising (2500-4000rpm), but enjoy the upper rpm range from time to time when solo
4. I'm looking for low-mid power.
Old 04-11-2016, 01:37 PM
87gtNOS's Avatar
87gtNOS
87gtNOS is offline
Originally Posted by bklynbob
Stay 103. Headwork decked .020 a cometic .036 gasket and a Cyclerama 570 or a T Man Torqster. a 31 tooth Baker pulley would be a good addition.
31T BAKER pulley....tell me more.
Old 04-11-2016, 08:58 PM
roadrash3's Avatar
roadrash3
roadrash3 is offline
I second what others said call the experts and see what they say. I dealt with Bob at Fuel moto and could not be happier with my 107" i had to dyno it to really wake it up, but with the cams and level b heads its awesome
Old 04-11-2016, 09:06 PM
gipper's Avatar
gipper
gipper is offline
rash3: Same here on my FM 107" build. Bob at RC Cycles did my tune, and nailed it. You?
Old 04-11-2016, 09:35 PM
nevada72's Avatar
nevada72
nevada72 is offline
Received 26,068 Likes on 12,184 Posts
That.
We're talking 4 cubic inches on a 900 lb bike. With the head work and cams you will get results.
Btw, had a 107. Have a 103 now.
Old 04-11-2016, 09:40 PM
Mike's Avatar
Mike
Mike is offline
I've been down this road.
assuming similar compression, heads, cams, exhaust, etc.... the difference between a 103 and a 107 will be around 3-4 hp and 3-4 ft lbs tq. By the time you do exhaust, heads, cams, set the compression, get the thing tuned, you've extracted most of your performance. The four additional cubic inches will not make a big difference at that point.
The only reason I'd take a 103 to 107 is if I was going to change the pistons anyway. If you're planning on 107 with flat tops, and a compression of under 10.5, just keep your 103.
If it were my motor, and I was bound and determined to redo the whole top end (without boring cases), I'd do the SE 110 bolt on kit, instead of any of the 107 kits.
Quick Reply: Cams + 107 v Cams + heads....?
