Anyone swapped lower forks on a 2014-2016?
I searched around but wasn't comming up with much for the new 49mm forks on the rushmores
Has anyone swapped thier lower forks to chrome or PC? I've done many leg swaps on the older forks but looking at the service manual it looks more complex with a cartrage style using few speciality tools I don't currently have .. Anyone done a write up or am have any pointers .. The local stealer wants 180 for just labor if I carry the disassembled parts in and have them re assemble them that just seems salty to me
Thanks chris
Thanks chris
I know the entire setup is different I think you misread what I was asking .. I'm not looking to convert anything I'm going to swap the Lower stock forks for a chrome set ..
Thanks chris
Thanks chris
The only "specialty tools" I needed were 2 large allen-style wrenches for the top caps and bottom bolts--the ones that hold the forks together and seal the oil in on the bottom.
I have alternative tools on hand that I have made to address these two things, since they are bigger than any standard allen wrench or socket extension allen that I have in a proper kit.
The fork assembly is no different than any other semi-modern right-side-up fork with two internal bushings and an oil seal. Easy-peasy. Oh yeah, PVC pipe of the right diameter makes a good bushing and seal driver. I guess that's another "specialty tool".
I went with a chroming vendor from California, who pre-sent out a set of chromed replacement lowers, and refunded the core charge (less shipping one way) upon returning my stock lower legs.
Here's a pic or two:
All the best,
Shane
If you're swapping lowers on the Rushmore touring model "low" then yes you will need specialty tools for the cartridge fork on the left fork, it's called the "fork spring compressing tool". The procedure itself is not difficult but I don't have anything written up for it. I'm sure there's something on YouTube though.
Mario77746
01-06-2009 12:00 PM
johnwwwatson
10-13-2008 03:11 AM
PoBoyGlide
02-11-2008 11:44 AM
