shifter shaft seal leak problems....
Hey has anyone had to get the shifter shaft and sleeve replaced from inside the transmission. I had a shifter shaft seal leak so I broke it down and repaired. Well first ride there was oil everywhere so back apart it came. I got a new seal and installed it, I can spin the rear tire manually and see some of my pink tranny fluid still leak past the brand new seal. The shaft is not damaged or nicked but does have alot of side to side play like it or the sleeve it sits in is wore out causing it to be out of tolerance for the seal. Guess it might be a trailer trip to the harley dealer as I do not feel comfortable pulling transmission guts to replace the shifter shaft.
I believe so, I removed old seal, cleaned inside with a q tip. Taped off the splines on the shaft, lubricated new seal and slide it onto the shaft till it met the housing. At that point I took a deep socket the same diameter as the hole and seal and pressed the seal as far back as it could go. Not sure why it will not seal. There is alot of lateral play. I have tried 2 new seals now. maybe 3rd time is a charm while it is still apart.....
Originally Posted by fournierrandy
At that point I took a deep socket the same diameter as the hole and seal and pressed the seal as far back as it could go...
I am curious... as to why you have lateral play. Without asking more questions... I'd say your shift shaft sleeve is excessively worn and needs to be replaced. The shift shaft itself should not have wiggle room (not that much anyways) because the sleeve is pressed into the case, the shift shaft slides through the sleeve and although it (obviously) rotates during gear selection... the seal is only supposed to do just that... seal not secure.
This may be contributing to the problem. When I pressed in my seal... the tool recessed the seal maybe a millimeter or 2mm beyond the case. The seal did not make contact with anything. Now, if you are worried about spill out from the OD of the seal and the case... you can apply a very thin coat of permatex and recess the seal.
Yes the shaft or the sleeve has to be worn out. The seal is seated good and I have had 3 seals leak now. It has way to much play so when shifting it causes the shaft to move allowing the seal to open up and leak oil past.
