Just bought a 2008 Street Glide, When Braking It's Not Smooth...Warped Rotors?
Old 03-30-2016 | 07:48 PM
Wick001's Avatar
Wick001
Default Just bought a 2008 Street Glide, When Braking It's Not Smooth...Warped Rotors?
I just picked up a 2008 Street Glide with 12,500 miles on it for $11,500. Good Deal? Bike is mint.
Anyways, when pulling the front brakes while riding, the braking action is not smooth at all, feels like warped rotors pulsating.
I took the calipers off, inspected all the brake pads, lightly sanded them smooth, and took a scotch bright pad and brake cleaner to the front rotors, put it all back together and same thing is happening.
Must be rotors?
Old 03-30-2016 | 08:09 PM
jaxdwg's Avatar
jaxdwg
Must be rotors?
Once, when I changed tires I put a bit too much pressure on a rotor. Acted just like a warped rotor feels. I put a dial indicator on it and it was tweaked. I used giant channel locks and trued the rotor. I now have 120k on it and still smooth as glass. Put a dial indicator on them and see for yourself, then decide whether to straighten or replace
Old 03-30-2016 | 08:42 PM
ohiomike's Avatar
ohiomike
my `06 "bunny-hops" actually bounces, think it`s the fork oil,( low in one fork) had a leak and Indy shop tightened upper fork bolt, but I don`t think he filled it back up. had similar issue on my softail that leaked from seal.
Old 03-30-2016 | 08:53 PM
xcbullet's Avatar
xcbullet
I used adjustable wrench over two pieces of steal. Nice little pull in the low spot went from .015 to .005 both rotors on front.
Old 03-31-2016 | 05:12 AM
todd-67's Avatar
todd-67
I had one of the fronts warp at 30k on my 09. I just replaced both fronts.
Old 03-31-2016 | 05:42 AM
dajogejr's Avatar
dajogejr
First thing to do is make sure all 4 pistons are pushing the pads.
At 35K on my 05 Ultra I replaced my rotors, I was dumb, I went cheap and bought solid rotors again.
I can hear it just start again.
New pads and floating rotors are on the docket this year.
You may have to extend the pistons, clean up the exposed and make sure they're all working.
Old 03-31-2016 | 05:48 AM
grbrown's Avatar
grbrown
Tha chaps above have covered the likely problem, but if you bought from a dealer, have a word with them.
Sonny81
05-01-2015 10:06 PM
bucket13
09-12-2011 06:16 PM
spokes54
07-14-2011 03:38 PM
Streetrunner
02-12-2011 04:48 PM
52edub
05-22-2008 09:15 PM
Quick Reply: Just bought a 2008 Street Glide, When Braking It's Not Smooth...Warped Rotors?
