18" front wheel on rear? (2008 Touring)
03-29-2016, 01:09 AM
Will an 18" front wheel from a 2008 Street Glide fit on the rear of a 2008 Road King as a straight swap?
I don't wanna mess around with spacers and whatnot.
03-29-2016, 01:16 AM
I doubt it. Front wheels are drilled for 2 rotors, rear haS a rotar and a pully. I could be wrong though
03-29-2016, 01:18 AM
Quote:
Originally Posted by
sbeast
I had heard the pulley and rotors share the same bolt pattern and thread size.
03-29-2016, 04:59 AM
No, no provision for the cush drive pulley. Look up wheel pics and you'll see the difference.
03-29-2016, 07:22 AM
TF3N
You heard wrong my friend. Won't work.
03-29-2016, 08:40 AM
and even if you could, it doesn't mean you should...
03-29-2016, 09:04 AM
No, as mentioned, however the rear wheels will swap!
03-29-2016, 09:32 AM
Related question, can the front from the SC be swapped to the Ultra? If both are 08.
If the rears can be swapped. I would assume the front could?
03-29-2016, 10:56 AM
cprhed
Related question, can the front from the SC be swapped to the Ultra? If both are 08. If the rears can be swapped. I would assume the front could?
The front is a whole different animal. Lots of years to choose from for front fitment. But to answer your question...Yes.
And I'm assuming you meant SG.
03-29-2016, 04:10 PM
Correct. I meant SG. Thanks.
Andycalifornia
07-02-2018 03:59 PM
OPDSam30
07-30-2014 01:18 AM
bradleys1320
04-19-2014 10:58 AM
jasong
Wheels/Tires
03-04-2012 09:16 AM
Bigsta
06-14-2008 08:40 PM
