Bike dies when put in gear
I have a '10 street glide and it suddenly just died. Red key light on dash flashed and no power, no lights nothing.
I checked fuses, battery connections all good. Turned ignition on then got power but when I put in gear she dies.
Any ideas what could be the problem.?
The issue was a wire in the casing by the frame neck on right side.
About 6 months ago I had an issue of engine light coming on with thw codes. A local shop discovered the wires by frame neck where broken.
Somehow they must have not connected and secured the wires well because the hot wire either broke or separated again.
All fixed and running now so all is good. Lesson learned if happens again. ..check battery, fuse and wires by frame neck.
