I started bike yesterday and the blue high beam light was lit even though the switch was not in high beam mode, the headlight was not lit at all but the passing lamps were on as normal. when switching to high beam mode the headlight comes on very dimly. I flipped awitch back and forth to no change. was putting bike back in garage and the lights went back to working correctly. today same senario to a t except when I rode to dinner the ride home was with out the headlight lit. only the passing lamps. when I got home putting it in the garage the headlight lit up. is it possesed. any ideas?? I will start with multi meter tom. I put it on trickle charger for the night. Thanks in advance.
I couldn't wait until tom. so I pulled the seat off to check battery connections and there is alot of corrosion on both posts, I just cleaned all of this 5 months ago I guess I will replace battery and possibly the battery cables. now the which battery ? is on the table
the headlight connection was the issue, just a poor connection. I sanded down the blades and put a little dab of grease on the and she is good to go. headed for a ride to make sure it is fixed. thanks again for the reply you were dead on
