clutch woes
clutch woes
So I have had the most hellacious time with my clutch. all started with a broken fairing bracket. disconnected clutch, fixed bracket.
put it all back together and i can not for the life of me get the clutch to do what it's supposed to. I have adjusted it "the easy way" and by the book multiple times, and i can't get bike to roll easily with the bike in gear and the clutch pulled in. I did this multiple times before thinking maybe starting the bike would change things.. and bike seemed to idle high (might of been in my head) and was making a racket, i shut er down before attempting a shift. I have taken apart the transmission side and checked and re-seated the ball bearings. i took apart the clutch pack assembly and checked it out and re-assembled. and i have gotten exactly no where. I have adjusted the clutch on this bike before without issue.
I pride myself on doing all my work but it looks like i have met my match and i have absolutely no clue why. any thoughts?
9 time out of 10, you are leaving it too loose. Be sure cable has a slight amount of play. You want to be able to move the plates. Screw the adjuster at the clutch in to no play and couple turns further to debut fine thread. Now come back out and then back in moving the clutch lever to you know you are filling the no play. Now back of your 3/4 turn, and snug the lock nut. Adjust the cable play to just a 1/16. If that does not fix it, you have warped plates, bad throw out bearing or tight cable. Doubt cable is bad on an 09 and unless you abuse it, clutch is OK since they are tough.
Frank Dukes (03-22-2016)
This isn't a clutch problem.
I have admitted defeat and will be calling dealer in the morning.
Because you have taken off everything necessary to remove the clutch basket and the trans cover... i'm at my witts end just reading everything.
during the clutch adjustment... when you say you did it by the book... so you drew the clutch cable adjuster inward all the way so that there was absolutely ZERO tension what-so-ever at the clutch lever? Then you adjusted your clutch (backing it off and tightening it down), then went back to the clutch cable adjuster and began backing out the adjuster to tension the clutch lever?
Basically I'm at the point where i order a whole new performance clutch, throwout bearing side internals and try this **** over again or call the dealer and let them pick the miserable bitch up. I'm gonna think it over til after work and make a decision.
I know if you buy a new oil spinner/throwout bearing - it is pressed onto the spindle as opposed to it being a single piece. So its best to buy the little (nearly negligible cost) bearings, new rod, and clutch side pieces. And for the love... when you push off the circlip... put a piece of electrical tape around it... mine flew off and vaporized mid air.
If you end up with a performance clutch... I'd get a new cable and easyboy lite.
Keep us posted.
Keep us posted.
