Engine detonation and just runs like crap
#31
#32
No IAC on TBW bikes. 07 was last year for the IAC. Sounds to be me like she's only running on the front cylinder when hot. I would mention safety issue and liability next time you are speaking with the service manager. It's why you have warranty. Check spark with a spare plug first that you know works. Could be simple as a lose boot on one plug.
#33
#34
#35
Great advice. Your just driving yourself crazy at this point. Save yourself some grief and take it someplace else.
If they tell you the same thing as your current dealer then consider that it is all in your head and you are already crazy.
#36
#37
First thing is get rid of the street tuner. It only allows canned EPA maps and very little if any adjustments. The street tuner will have maps that are lean. Lean means it will run hotter. Check out the things others have told you to check and if all those things are good get rid of the street tuner. If you want to stay with Harley products go with the SEPST(pro super tuner). It will allow a good dyno tech to tune the bike. There are other flash tuners out there that work just as well.
At the very least I can hook the tuner up and view in real time all the sensor and output values to see if I can spot any abnormalities. Since I already have it and the harness is installed can it possibly hurt anything to leave it?
Thanks for your input.
#38
I believe I have reached that point. This entire episode has really started to pi** me off. I'm growing very tired of being told that's just the way a Harley is when the first 10 months I owned it it ran just fine and I loved it. Now it runs like sh** and I 'm more or less being told get used to it. They ride it and tell me they can find nothing wrong.
Sooner or later I'll get a handle on this.
Thanks.
Thanks.
#39
#40
Thanks.
