Coil to cowbell relocation
Removed the horn from the cowbell and mounted the coil inside the cowbell utilizing a little ingenuity. Now...what I can't seem to figure out is that the length of the wire that energizes the coil is too short and I don't know how to get it to the coil. I can pull it from the plastic tray that sits under the tank and run it straight down to the coil but looks horrible. Any ideas that have worked for some of you? 2008 FLHX is what I'm working with. Thanks in advance.
Been there don that; might be pictures in my garage. I think I modified the cowbell bracket to hold the coil inside of a soft tail style coil cover. Hiding wires was the easy part.
After a year or two I ended up with Accel Super Coils, right on top of the plugs. That and the S&S power tune headers were the best midi ever made.
scubahsteve (03-17-2016)
We have the Plug-n-Play extensions that are part of the Softail & Dyna coil relocation kits. It is the same coil and wiring for the Touring models.
They'll be able to fix you up with what you need.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
OR
