Advantage to lower the front ?
2012 street glide with 21 inch wheel in front. Just installed Burly Slammers in rear. Would I feel a big difference in the ride/handling if I also dropped the front? Love the look, but haven't got out and rode it for any length yet, just finished the install. What have you guys done? Suggestions?
Thanks, Jeff
Thanks, Jeff
Thanks, Jeff
Thanks, Jeff
James
1st of all, how was installing a 21 inch wheel a mistake? Vastly improves the look of the bike. I did get out and ride it this evening, so tell me James, how did I totally ruin the ride of the bike?
Just like some input from you guys that have dropped your front ends. I know it'll help to level the bike out and all that. But will it really make a big difference in the handling! I'm used to riding rigid and all that, so I don't need to be sitting on a Cadillac! I do like my SG though and just wanted some opinions
Received 5,424 Likes
Lowering front and rear with a 21" front wheel is not a problem in handling. In fact mine tends to do a better job tracking straight at higher speeds on the interstate now. Only drawback with lowering the bike is shorter shock travel and stiffer ride. You can lower them and keep the soft ride but out front you risk hitting the fender on some parts of the bike and in the rear, if using those cheap assed lowering blocks, can possibly hit the inside fender with the tire or the shocks rub against the bags.
In the front I used the Arlen Ness 1 1/2" shorter dampner tubes, which you can use your stock springs with. I would personally recommend either running a spacer on top of the springs for more preload (about 3/4") or running the fork oil much higher in the tube than the stock recommendation. Either of these will stiffen the forks or shorten the travel. I did both on mine to avoid hitting the crossbar and oil cooler. Its stiffer riding but no problem with handling at all.
In the rear I used bitchinbaggers.com and sent my shocks to them and had them lowered 1 1/2", it actually rides better in the rear, if I don't pump a lot of air in them, and no contact of tire with fender.
Lots of ways to lower the bike, some cost more or less money or more or less work.
