Silicone or Gasket sealer on breather bolts
Silicone or Gasket sealer on breather bolts?
Tech recommended against using silicone or gasket sealer on breather bolts saying engine heat will just cause it to liquify and run out. Install instructions say to use it to provide a good bond with 18ft lbs of torque. Being hollow they will twist or break easily if over tightened...any suggestions as to which is the right answer?
Thanks fo the replies. It's a Hammer high flow and they suggested the silicone/gasket sealer. Normally I'd go with the tech advice, but Hammer seems to know their stuff usually. Was having concerns reconciling the two viewpoints. High temp silicone seems like a good answer. Blue loctite is for sure going on the internal assembly bolts. Thanks all.
Permatex makes a sensor safe (500*f) and high temp (600*f) gasket sealer. Both are silicone. Is there a better product? What is the right high temp non-silicone paste? Will it be sensor safe? If I go with blue loctite won't the heat be an issue or does it require higher temps? I know with red loctite heat is the main agent used to weaken it when removing the bolts....
What will the silicone do to make removal worse?
