Roadking balance issues?
RE: Roadking balance issues?
ORIGINAL: nvsteve
With your cruise control on and hands off?
ORIGINAL: FLHRSteve
I have a '07 Road King Standard... Tracks perfectly straight with no hands ... [sm=shades.gif]
Bike tracked perfectly straight whle I was defrosting my fingers. [sm=signs007.gif]
ORIGINAL: FLHRSteve
Yup.. the reason I know this is because two weekends agowhen I went to the 'Louie Run' in Painsville, I was riding across I-90 early in the morning with the cruise set to about 65.It was like 35* out andI kept pulling both of my hands off the bars to rub them together cause the tips of my fingers were freezing.
ORIGINAL: nvsteve
ORIGINAL: FLHRSteve
You added cruise control.
Glad your yours tracks straight. Looks like most don't.
I asked this question several months ago, and never got what I thought was a satisfactory answer. Maybe because there ain't one. Yep, my 02 pulls left as well.
Can't be the clutch as was mentioned above, as I had the whole front end off adding cruise just this past weekend.
Keep in mind that all your drive line is on the left side. It will act as a gyro at certain speeds. That will cause a slight lean to the left.. Except changing speeds there is no cure for that.. It is all weight and balances. Mine tracks straigh but I also have a heavier bike..It should not happen when you are two up cause that changes the weight (alot)(meaning) 100 lbs makes things change a lot..
Mine will "pull" one way or the other depending on how the saddlebags are loaded and of course the crown or crest or wheel tracks in the road. I just pay attention to loading the bags equal as possible and if i have a lot of gear in the right bag which is usually the case I will toss a few bottles of water in the left to equalize the load and have extra water. Keep an eye on tire wear whick could indicate a alignment problem. I went through the repair manual and checked that everyhting was set up ok per the manual for peace of mind too.
