Removing cable from switch housing
Replacing cables on my 01 FLH. Throttle side went OK. I can not get the idle cable loose from the switch housing. I have put a drop of oil on it, and tried wiggling it as I did with the throttle cable to no avail. It is plenty loose in the housing just wont pull out. How should it be done, without damaging the housing?
Thanks,
Thanks,
You have to loosen the lock nut and turn the adjusting **** to loosen up the cable. Then you have to remove the pin in the clutch lever to free up the lever. That is the only way that I know that you can do it. To remove the clip on the pin, you have to use needle nose pliers. Be very careful not to loose that clip.
There is a video showing how to do it on utube.
Hope this helps
Hope this helps
oinker02
01-17-2010 08:42 AM
