2014 SG front wheel on 2008 SG
Old 03-13-2016 | 08:32 AM
just plain john's Avatar
just plain john
Originally Posted by tflatgard135@hotmail.com
Does your suppose I'll have to purchase the break lines also?
The later model front master cylinder has a different bore size than the early ones, and the brake lines are different. That said, I reused both components and the Brembo calipers. The brake lines bolted right up. I have often wondered if swapping to the later model master cylinder and lines would be better. The early rotors are 11.5 inch, and the Enforcer discs are 11.8.
Old 03-13-2016 | 08:51 AM
multihdrdr's Avatar
multihdrdr
Originally Posted by SBates08
...This has certainly been a first for me pertaining to the caliper. Very odd.
Here let me correct the title...
2014 SG front wheel on 2007 SG ...... (or 2006...or not even a SG...who knows at this point)
How odd now?
Old 03-13-2016 | 03:05 PM
lt1-xjs's Avatar
lt1-xjs
How odd now?
Puzzle solved.
Old 03-13-2016 | 04:27 PM
SBates08's Avatar
SBates08
Here let me correct the title... 2014 SG front wheel on 2007 SG ...... (or 2006...or not even a SG...who knows at this point) How odd now?
It's odd that an 08 doesn't have Brembo calipers. Never seen that.
This going on the presumption that this is actually an 08 SG.
Old 03-13-2016 | 04:46 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by lt1-xjs
Puzzle solved.
And you probably still haven't
What gave you the idea?...because someone said so?
Old 03-13-2016 | 04:53 PM
SBates08's Avatar
SBates08
And you probably still haven't What gave you the idea?...because someone said so?
Because the OP said it was an 08. Presuming he knows what he's got.
Old 03-13-2016 | 05:08 PM
multihdrdr's Avatar
multihdrdr
Sbates you're still not getting it...don't you see my winks
Yes, logic says use what they say, but sometimes you have to just Forget that...people say a lot of things.
Especially when it doesn't matter in terms of a solution.
Old 03-13-2016 | 05:36 PM
SBates08's Avatar
SBates08
Sbates you're still not getting it...don't you see my winks Yes, logic says use what they say, but sometimes you have to just Forget that...people say a lot of things. Especially when it doesn't matter in terms of a solution. . . .
Wink wink nod nod yeah I had a blonde moment. 😳
Old 03-13-2016 | 05:43 PM
tflatgard135@hotmail.com's Avatar
6th Gear
I'm just as puzzled as you guys. Took it into the local shop and they didn't understand why either. But Vin #'s match up as an 08. I've got some brembos on order. One guy did mention to me it could have been a hold over from 07 and ended up getting registered as an 08. Still wouldn't make sense to me. If you guys find a legitimate answer let me know because I've been puzzled over this myself for a few days now
Old 03-13-2016 | 05:50 PM
lp's Avatar
lp
You been asked a few times but you have not answered yet, do you have a 6 gallon tank and do you have throttle cables or is it fly by wire? That will tell us loads.
Quick Reply: 2014 SG front wheel on 2008 SG
