This should be easy
This should be easy
Hi all,
Just got some chrome switch covers to replace the really faded ones on my 07 Ultra Classic but so far not so easy. So, I am looking for some wisdom here for two challenges.
1) The throttle cables will not pull through the bottom of the lower housing. Any tips here?
2) The assembly that contains the turn signal switch and two others will not come out of the lower half. I have removed the two screws inside the housing that hold this assembly in place. I also found and depressed the button on the side of the housing that allows one end to start to pivot out but it is hung up on the turn signal button. How do you get that assembly out?
Thanks
Thanks
