View Poll Results: "Touring" BREMBO Caliper UPGRADE - USING Original Master or Brembo?
Ugraded to "Touring" Brembos & Re-used 2000-07 Master Cylinder (with correct fluid) - All Good
30.77%
Ugraded to "Touring" Brembos & Re-used 2000-07 Master Cylinder (with correct fluid) - No Bueno
0%
Ugraded to "Touring" Brembos & Master Cylinder - Glad I Did it
30.77%
Ugraded to "Touring" Brembos & Master Cylinder - "Big Deal" about Nothing
0%
Haven't Upgraded Yet - But Want To
38.46%
Voters: 13. You may not vote on this poll
POLL: "Touring" BREMBO Caliper UPGRADE - USING Original Master or Brembo?
Upgrading the 2000-2007 Brake Calipers to 2008-later Brembos is common. Some additionally change the Master while others re-use the Original. The Stated Results Vary and are sprinkled around the Forum. Central Point Accumulation and Access is my goal.
Comments Are Welcome
Your choices will be as follows (please vote at top of page)
1. Ugraded to "Touring" Brembos & Re-used 2000-07 Master Cylinder (with correct fluid) - All Good
2. Ugraded to "Touring" Brembos & Re-used 2000-07 Master Cylinder (with correct fluid) - No Bueno
3. Ugraded to "Touring" Brembos & Master Cylinder - Glad I Did it
4. Ugraded to "Touring" Brembos & Master Cylinder - "Big Deal" about Nothing
5. Haven't Upgraded Yet - But Want To
"More options? We don't need no stinkin' more options!"
I'm not sure I can edit the POLL portion even if I wanted to (without a Mod's "help" that is)
But if I could, I might just change #5 to: "Haven't Upgraded Anything Yet - But Want To change One or Both"
That would cover you
Switched to Brembo's front and rear and kept the stock 2001 masters and levers,many claim you need to switch them as well,seems to work fine.I did it over the winter as well as changing tires and wheels,swingarm and bushings so no valid way of comparing before and after.Has anyone one done a true measured test under controlled conditions to see if the braking is improved(or not) with the changed parts or do most just offer their opinions with no data to back it up.
