View Poll Results: "Touring" BREMBO Caliper UPGRADE - USING Original Master or Brembo?
Ugraded to "Touring" Brembos & Re-used 2000-07 Master Cylinder (with correct fluid) - All Good
30.77%
Ugraded to "Touring" Brembos & Re-used 2000-07 Master Cylinder (with correct fluid) - No Bueno
0%
Ugraded to "Touring" Brembos & Master Cylinder - Glad I Did it
30.77%
Ugraded to "Touring" Brembos & Master Cylinder - "Big Deal" about Nothing
0%
Haven't Upgraded Yet - But Want To
38.46%
Voters: 13. You may not vote on this poll
POLL: "Touring" BREMBO Caliper UPGRADE - USING Original Master or Brembo?
Old 03-08-2016, 11:35 AM
JR-Boston's Avatar
JR-Boston
JR-Boston is offline
I got a 2008 Brembo HD Touring master cyl, calipers, & rotors on eBay. It came with a matching clutch lever too. The new front brake line I got from a dealer & filled with DOT 4. The Brembo calipers bolt right on the 2004 forks, and the Brembo rotors bolt right on the 2004 wheel & line up nice. The improvement over my original 2004 system was huge, easy swap too.
I put a Brembo caliper & rotor on the rear too, but had to hone the caliper arm from 25mm to 1" axle, then it went on fine. When I realized the new Brembo master for the rear might require welding it onto the frame, I went with a new (clean) 2004 rear master & filled with DOT4. Rear works ok, and it's much easier to get the rear caliper off now (unbolts from the arm), but I think the rear would work better with a matching Brembo master.
JR
Old 03-08-2016, 11:58 AM
lt1-xjs's Avatar
lt1-xjs
lt1-xjs is offline
I put my Enforcer wheel a year and a half ago. Used the stock 2002 master cylinder and flushed the 2014 calipers with denatured alcohol and blew them out with compressed air. Filled with new Dot 5. Works great.
Old 03-08-2016, 12:17 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,313 Likes on 1,861 Posts
Originally Posted by JR-Boston
...I put a Brembo caliper & rotor on the rear too, but had to hone the caliper arm from 25mm to 1" axle, then it went on fine. When I realized the new Brembo master for the rear might require welding it onto the frame, I went with a new (clean) 2004 rear master & filled with DOT4. Rear works ok, and it's much easier to get the rear caliper off now (unbolts from the arm), but I think the rear would work better with a matching Brembo master.
JR
Yep...going the extra ...Good Info
Although most people doing the Brembo swap would be doing the front only
Old 03-08-2016, 12:21 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Cool
I'm doing both ends as well. In addition to honing the rear caliper mount an additional axle spacer is needed, to make up for the difference in thickness between the two generations of mount.
Old 03-08-2016, 12:37 PM
multihdrdr's Avatar
multihdrdr
Yep...more reasons for you to stay with Dot5
Original to bike
No changing master cover
No mismatched fluids front and rear
No concern with paint damage
All Good
Old 03-08-2016, 12:40 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by grbrown
I'm doing both ends as well...
"doing both Ends"...You go girl (oops)...Atta boy GR
johnnythrottle
06-03-2016 03:03 PM
F86
01-20-2016 12:50 PM
FlaTriker
07-31-2014 02:11 PM
SpiderPig
Touring Parts
05-17-2012 07:35 PM
spaceblue
02-15-2011 11:02 PM
Quick Reply: POLL: "Touring" BREMBO Caliper UPGRADE - USING Original Master or Brembo?
