2006 street glide, stock radio, stubby antenna. Whenever I turn my bars at a stop, my radio reception cuts out. Any ideas how to fix it. The antenna wire in the fairing seems solid, so im not sure what's causing it
Any electrical mods, like extended handlebar wiring (for apes)? Lift the front wheel off the ground, so you can easily turn the bars and experiment with the radio switched on and jiggling the wiring etc. Many electrical problems are actually mechanical, caused by things such as a pinched or damaged wire, loose connector (as Ken above suggests).
