Adjustable rider backrest question ...?
After I did similar adjustments to my adjustable backrest, I was not happy with how it fit up thru the slot in my sundowner seat.
The easy remedy for that, if you encounter it, is to elongate the screw hole in the rear of the seat tab (Where it attaches to the rear fender) to make an adjustable "Slot" where you can move the seat forward or backward, then tighten down the screw and you are done.
It didn't take much, you can use a small round file - I used my dremmel tool.
I was concerned that without the rear seat tab slot adjustment, it might have damaged the upholstery over time of on/off, back/forth, and so on.
Remember - IT DOESN'T TAKE MUCH.
dh_meyer
2014-2023 Touring Models
05-20-2015 05:56 PM
