***Warning****
Well damn. If you have plenty of time you could get the HFSM with two Fobs for 287.00 from Boardtracker. Then you'd have to have it programmed.
Does anyone know if I pruchased the components from a running bike if its just a matter of plug n play. say i got this
http://www.ebay.com/itm/8581-2008-08...RWuhs-&vxp=mtr
is it as easy as swapping the parts?
But first I'd give them the VIN and see which dealer sold the bike and what dealers did any recall work and try to contact them. They may have owner information. If they won't tell you who it was they might call the previous owner and get the code for you. Might save you a few Benjamin's
Is your bike a 2008?
Good luck
Bill
I'd call the HD Tech Line and ask 1 800 258 2464 if it's plug and play.
Good luck
Bill
Good luck
Bill
anyone on here from Redman michigan previously own a 2008 ultra classic that they dropped and insurance totaled that belonged to the local plumpers union in Detroit? anyone? Bueller?
It's almost plug n play.
When you install the new security module there is a learn process the bike needs to run through, should be able to find the info online as I don't have it anymore.
Anyway the other electronic components in the bike need to learn the new one, once the process is complete I think it should work.
I installed security in my 2009 myself, went through the learn process and all was good. I did however need to get the dealership to program the fobs but only because it was a brand new system, I'm thinking that if you are installing one that has already been set up you likely wouldn't need to do that.
It's worth a try.
I can't believe they can't program a new fob without an old one, just doesn't make sense.....
