bike wont sart , any ideas
battery is up on bike and batterys in my fobs seem to be ok. turn on at the lock an unlock and hit the run switch, I hear pump turn on hit start, nothing just like the fob is not on you. did this at gas station yesterday but after turning every thing on and off a few times it finally started.
sorry for the spelling. ok I turn on ignition then flip switch to run, I hear pump come on and then press start but nothing happens. at the station I just turned ignition off an flipped the run switch off a few times and it finally started but I don't really think that had anything to do with it starting I think I just got lucky, we have a local indy here in town ill take it to that will be not as hard on pocket. don't have meter.
You have a touring bike of unknown year , miles and condition.
1-You report having no meter but state that " battery is up on the bike".
*A translation would be required...I will take a wild guess that you might mean the lights are bright/strong on bike.
2-You report "my fobs seem to be ok" but you have no meter and have not checked fob batteries.
Do you mean physically OK? Does that mean you tested both Fobs?
Do you know the bypass code for security system?
Reason:This would allow you to deactivate security if fob battery is bad or if a Fob is sick.
3-You report " I hear pump turn on hit start, nothing just like the fob is not on".
I would change fob batteries first
Sounds like you need a new bike battery, how old is it?
