14 SG Enforcer wheels w/ ABS on 12 SG w/out ABS ???
Old 02-18-2016 | 02:11 AM
brymer84's Avatar
brymer84
Default 14 SG Enforcer wheels w/ ABS on 12 SG w/out ABS ???
Looking to install a 14 Enforcer wheel and rotors with ABS on my 12 SG without ABS. My understanding I will need to swap out the ABS bearings for non ABS bearings ? Anything else needed for this swap ? Where is a good resource to find non abs bearing ?
Old 02-18-2016 | 02:25 AM
BigJ37's Avatar
BigJ37
I just did this on my 2008 street glide, either swap bearings or use diff spacer. I bought spacer from a fella on here.
Old 02-18-2016 | 06:33 AM
mjonesjr84's Avatar
mjonesjr84
New bearings is all you will need.
I priced the ABS spacer when I did this to my '08 and found it was cheaper to get new bearings put in (both sides). The right side bearing is the same, so if you know the wheel has lower miles, you can just have the left side bearing replaced.
Old 02-18-2016 | 06:57 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Get the non-ABS bearings from your local Dealer. They're not going to put you into poverty.
Old 02-18-2016 | 11:32 AM
JMC22's Avatar
JMC22
Change the bearings and your done...
Old 02-18-2016 | 12:58 PM
GEORGEW's Avatar
GEORGEW
I bought a set for my 2012 RGU,, Sent them to SportChrome last year and all I can say is they are still just like New Wheels..
http://www.sportchrome.com/
Attached Thumbnails 14 SG Enforcer wheels w/ ABS on 12 SG w/out ABS ???-my-rgu-1.jpg   14 SG Enforcer wheels w/ ABS on 12 SG w/out ABS ???-my-rgu-2.jpg
Old 11-12-2022 | 03:04 PM
fans24x2's Avatar
fans24x2
Stage II
Default Spacer
Can you send me the guys in information for that spacer?
Old 11-13-2022 | 07:29 AM
jake24lt's Avatar
jake24lt
blackscootersociety
Wheels/Tires
01-16-2017 06:09 PM
glock221
05-08-2014 11:32 PM
EasTexUltra12
08-21-2013 08:17 PM
dabo0652
01-30-2013 06:25 PM
Bagger71
04-20-2012 10:59 AM
Quick Reply: 14 SG Enforcer wheels w/ ABS on 12 SG w/out ABS ???
