PC III w/SE slip ons?
Any benefit to adding a PC III when I am running the SE touring slip ons? I went to a local indy shop to have a PC III installed and they didn't even want to sell me the PC III because they told me that the SE slip ons were too restrictive. They told me that I wouldn't see any more power that would be noticeable. They suggested a set of true duals or at least a pair of V&H or Reinheart slip ons. Like they said, "we'd be glad to take your money for the PC III, but you won't be happy". It's just that I recently bought the SE slip ons and like the sound. Does this sound correct? Anyone have the SE touring slip ons and add the PCIII? Did you get any increase in power? I am looking for mainly as much low end torque as possible.
Thanks,
Dave
Thanks,
Dave
RE: PC III w/SE slip ons?
ORIGINAL: The Pawnbroker
Thanks,
Dave
Thanks,
Dave
Sorry I didn't include more info. As I told them, I have the SE slip ons, the high capacity A/C and the HD ECM download already. Basically I've done a stage one. I still would like some additional torque. I really like low end grunt. That's why I thought adding a PC III would be the next upgrade. I realize that it negates the ECM download I just paid for ($150) because the PC III replaces that programing
Thanks for any input,
Dave.
Dave.
i'm having the PCIII installed as i write this. I have the SE Slip-ons, with the SE A/C and Stage 1 Download. I still think it runs too lean at the lower rpms. Want to richen it a litte at the higher RPMs, also. I'm also hoping that the pinging gets reduced. Seems as it's gotten hotter here, the pinging has really started.
alexcue,
Who told you that it would make any difference with the SE slip ons? I have the exact same set up you do! I went to a well know indy and they told me no go. I would be disappointed. The more I think about it, the more I think they may be wrong. I stood there and asked them again if I was not understanding what they were saying because it just didn't make any sense to me.
Rush makes a very good muffler that has nice power and torque gains. I have the 1.75's which they claim are quiet but they got a nice bark and rumble like a V-8. I love em. http://www.epiflex.com/rush_touring.html scroll down and you can listen to em.
my indie told me, it should help. The Stage 1 is still an EPA compliant d/l.
btw, someone here posted a dyno sheet of our similar setup. What struck me was how lean it was at the lower (under 3000), rpms. Even at higher rpms, it was still not an ideal ratio. If it helps the heat issue, and gives me a bit more power it will have been worth it.
Dave.
Dave.
The other option in addition to or instead of the cam is to increase your displacement by going to bigger cylinders and pistons. In that case you'd probably want an Andrews 26 cam or similar grind to give you lots of torque down low. As you can guess, now you're starting to talk real money.
alexcue,
Are you changing your exhaust? That is what they told me was the problem. Also, please let us know if you notice any difference with the addition of the PC. I thought because the download was EPA compliant, I would be able to get a noticeable difference going to the PC.
RBJones,
Thanks for the input. Do you know if the cam change on a 96 makes as much of a difference as with yours?
Thanks again,
Dave.
RBJones,
Thanks again,
Dave.
i have a 06 electraglide classic withse touring slipons,kuryakyn skull air cleaner and the pc111.Jamie just dyno tuned it friday and got 76.24 hp and 78.03 max torque.the map he sent with the pc111 was off alittle bit but not bad,i gained 4 hp and 2 ft-lbs of torque.
