Wheeldock E-Z up Center stand TOP NOTCH!!!
Old 05-15-2007 | 09:50 PM
joesdad's Avatar
joesdad
Default RE: Wheeldock E-Z up Center stand TOP NOTCH!!!
i have both the center stand and the wheeldock..these are great products and customer service is top notch..there are no stability problems with either product
Old 05-16-2007 | 01:59 AM
iowacruiser's Avatar
iowacruiser
ORIGINAL: Dogwood
ORIGINAL: IndyRider
rtrostiii
Do you have the wheelchock boltedto the garage floor or is that not necessary.
You do not have to haveit bolted to the floor, the rubber ends hold it well when you run up on it.
The only issue is when backing out of the Wheeldock, it takes quite a bit of force and will pull the Wheeldock across an epoxy painted floor.
My solution was to just drill for 2 anchors and use 1/4-20 machine screws, this way it can be quickly moved when not needed.
Maybe a dumb question but.............. Are you pushing the back part of the wheeldock down and relocking it open before trying to pull the bike out of the wheeldock? I have no problems rolling mine out of the wheeldock with it sitting unsecured on the garage floor.
Old 05-16-2007 | 11:10 AM
bucs012's Avatar
bucs012
I would also like to know if you can still put your bike on a bike stand with the center stand mounted on. I have the Sears Motorcycle floor jack stand.
Old 05-18-2007 | 01:26 PM
bucs012's Avatar
bucs012
ORIGINAL: bucs012
Any of you guys with this center stand help me with this question? I would really like a center stand but want to make sure I can still get my bike on my floor jack as it also gues under the bike.
Old 05-20-2007 | 02:54 PM
hdjoe88's Avatar
hdjoe88
ORIGINAL: bucs012
ORIGINAL: bucs012
I have the same question. I like this center stand idea but my lift slides right into that "bowtie" frame piece. Anyone who has this product, can you still use your lift?
Old 05-20-2007 | 04:15 PM
Arvid's Avatar
Arvid
Another question, ... I would like to know if you need to dismount to operate this center stand. I currently have the HD front mounted center standthat I use when I'm 2 up with my wife onboard. I can lower the center stand before I dismount.
As for a Chock in the garage, check out Baxley, which doesn't need to be bolted.
http://www.baxleycompanies.com/
Arvid
Old 05-21-2007 | 05:39 AM
PapaTravis's Avatar
PapaTravis
Saw a guy on this board that had the wheel dock attached to a sheet of plywood. Would be easier to move the bike to a different location in the garage if it wasn't bolted in the concret.
Also, I don't have a center stand, but would like to add one. I ALSO want to know if the center stand will interfer with the bike being lifted by a motorcycle jack? Help us out guys. There are more than one of us that would like to know before we spend the money on a center stand.
Old 05-21-2007 | 12:53 PM
SSJ's Avatar
SSJ
No you don't have to dismount to get the bike on the stand put it down a roll back a little, my wife 130 lbs can get our Ultra on the stand by her self.
Old 05-21-2007 | 05:47 PM
rtrostiii's Avatar
rtrostiii
ORIGINAL: IndyRider
rtrostiii
Sorry it took so long to get back with you.........
No the chocks just sit on the rug. I have thought of perhaps putting a strip of industrial size velcro along the bottom bar for a little extra hold.
Djcamis
2014-2023 Touring Models
26
03-04-2020 03:55 PM
RogFel
26
03-20-2015 10:03 PM
Broncobilly72
EVO
02-02-2013 09:39 PM
cmc seabee
12-28-2011 03:49 PM
bradteed
11-28-2006 09:31 PM
Quick Reply: Wheeldock E-Z up Center stand TOP NOTCH!!!
