08 street glide front wheel
Old 02-15-2016 | 09:56 PM
Cozz's Avatar
Cozz
Default 08 street glide front wheel
Can anybody tell me if an 08 street glide front wheel is a straight bolt on , to my 04 ultra. Axle, rotors, ect.
Old 02-15-2016 | 10:38 PM
Munkee's Avatar
Munkee
Negative. You'll need 25 mm axle and spacers for 08-up for non abs.
Or change out bearings on 18" wheel to 1" bearings and 08-up spacers for non abs.
You use your old rotors either way.
Old 02-15-2016 | 10:41 PM
bigskyroadglide's Avatar
bigskyroadglide
08 was first year of 25 mm bearings, also first year of brembos. Your 04 has 1 inch bearings, so straight bolt on, no.
You can change the axle to a 25 mm one and use your 04 rotors on the 08 wheel and it will bolt on. Forks are the same.
Be sure to check your spacers and brake disc alignment.
Old 02-17-2016 | 12:44 AM
multihdrdr's Avatar
multihdrdr
OR
2008 Street Glide uses the same 16x3 wheel castings and bearing bore depths as the earlier ones. For 2008 only, Harley just inserted a bearing shim behind the "New" 25mmID x 15mm wide "Primary" bearing and used the longer 2008-later center spacer sleeve.
To use on your 2004, you'll need to replace bearings (& remove shim) with Std 2000-2007 1"ID x 21mm wide bearings and center spacer sleeve.
Swap rotors as previously mentioned
Old 02-17-2016 | 05:39 AM
SBates08's Avatar
SBates08
OR 2008 Street Glide uses the same 16x3 wheel castings and bearing bore depths as the earlier ones. For 2008 only, Harley just inserted a bearing shim behind the "New" 25mmID x 15mm wide "Primary" bearing and used the longer 2008-later center spacer sleeve. To use on your 2004, you'll need to replace bearings (& remove shim) with Std 2000-2007 1"ID x 21mm wide bearings and center spacer sleeve. Swap rotors as previously mentioned
^^^^^This^^^^^
But if I was gonna do this swap I'd go on up to the 18" Airstrike wheel.
Old 02-17-2016 | 06:55 AM
Cozz's Avatar
Cozz
Probably go with a 06-07 wheel, much better compatability. Thanks.
Old 02-17-2016 | 06:57 AM
SBates08's Avatar
SBates08
What do you mean by compatability? They're all compatible and the 18" wheel looks much better IMHO.
Old 02-17-2016 | 07:02 AM
Cozz's Avatar
Cozz
My tires are brand new, not looking to change the front size.
Old 02-17-2016 | 07:04 AM
SBates08's Avatar
SBates08
Ahhh that's makes sense.
HubBub
12-03-2018 08:36 AM
BluBeaSSt
10-21-2014 03:46 AM
cmckirdy
02-19-2014 09:37 AM
RFG7680
08-22-2010 07:46 PM
ameristo
01-14-2006 09:28 PM
Quick Reply: 08 street glide front wheel
