Hayden M6 BT07 primary chain tensioner initial impression
I decided to replace my stock chain tensioner on my 2012 Ultra with the Hayden BT07. I've read posts on this and other forums regarding the BT07. Most people seem to like them although a few have had problems with the chain being too tight or it making unusual noises. Those problems seem to be with earlier versions that have longer springs. I measured the springs that came in my kit and they are the newer shorter springs. I don't remember what the new and old measurements are. I found them in an older thread and checked the spring length a couple months ago when I received the kit in the mail. I made a video showing my impressions of the tensioner upon install. Here it is.
I'll post my impressions of it after I run it a few hundred miles later this spring.
I'm ok with it. The free play falls within the specs for a cold engine and there is still more room to compress the spring if need be. It's no different that having the spring ride over a rigid shoe with 5/8" to 7/8" free play. In either case the chain will tighten up when the engine is hot. With the Hayden, the spring will still have room to compress and give the chain more slack if need be.
My clutch started slipping becuase of all the melted plastic on the frictions, free play was within spec and I had about 7k miles on it. Pulled it when I replaced the clutch
