Hayden M6 BT07 primary chain tensioner initial impression
Old 05-31-2016, 07:21 PM
skydude426's Avatar
skydude426
skydude426 is offline
Originally Posted by seniorsuperglideE8
Had one in my 2013 FLTRU for 4k miles, the noise was unbearable, put the stock tensioner back in. I contacted Hayden about the "new" springs and a new shoe back in late 2014. Only heard from them once and that's their customer service. Like someone else said most expensive POS I've put on any of my HD's.
Your's had the older, longer springs. Just out of curiosity, what did the wear in grooves in your shoe look like after 4000 miles?
Old 05-31-2016, 07:30 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,979 Likes on 4,171 Posts
Cool test bed...Do it your self and measurements ..No BS or tin man spill. Test do not come any better then this for anyone on here..
Thanks.
Old 05-31-2016, 08:18 PM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 7,107 Likes on 3,651 Posts
Just had my primary apart and here is a picture of my Hayden tensioner after about 20000 miles and I have no issues with it.bit went back in.
Attached Thumbnails Hayden M6 BT07 primary chain tensioner initial impression-image.jpg
Old 07-09-2016, 10:31 AM
splattttttt's Avatar
splattttttt
splattttttt is offline
Just ordered one from Hayden. Lookin forward to the installation
Old 07-10-2016, 08:18 PM
skydude426's Avatar
skydude426
I've got between 1500 mand 2000 miles on the Hyden tensioner now. No problems. Seams to work fine. I'll post if anything changes.
Old 07-11-2016, 06:07 AM
splattttttt
What year is your ride?
Old 07-11-2016, 06:49 AM
skydude426's Avatar
skydude426
Mine is a 2012 Ultra. I have the M6BT07 tensioner installed. Sometime in late 2014 or early 2015 they changed the spring lengths and made them shorter. There were people having trouble with them putting to much tension on the chain. I read all the posts I could find on them before deciding to give one a try after they changed the springs. I wanted to install one in my bike because a year earlier I installed an M6BT01 in my wife's 2006 Ultra and we liked how it performed. I think most people have had good results in the 2001 to 2006 primaries with the BT01's. I started this thread to document my results with a BT07 now that the springs are improved just to show others how it works out for me. Next time I open the primary, I'll post about how it looks with another video. If I have trouble with it before I'm in there for another reason, I will post my results in that case as well.
splattttttt (07-11-2016)
Old 07-11-2016, 08:48 AM
splattttttt
The more threads on here providing feedback with anything relating our bikes the better.
Thanks for it
Old 02-06-2017, 06:37 AM
skydude426's Avatar
skydude426
UPDATE AT 4200+ miles
I opened up my primary this weekend to install a different cover. The Hayden chain tensioners has been problem free since install and if I wasn't changing the cover, I would have had no reason to open the primary.
With over 4200 miles on the bike since installing the Hayden tensioner I thought I'd make another video showing what I found while I was in there. The chain has worn into the tensioner shoe nicely. The grooves in the middle and sides appear to be the same depth as the chain links now, while the shoe surface that the chain rollers contact looks vertically untouched.
I've been happy with it so far and I have no reason to change to anything else. I don't think the chain is overly tight or loose and I don't have to worry about it becoming over tightened like the stock one can do on occasion.
Based on my experience, It looks like Hayden got it right when they changed the spring lengths in the M6-BT07. If anything changes or I have problems with it I'll post an update and another video. Here's a link to the video I made this weekend.
Old 02-06-2017, 09:47 AM
splattttttt
Thank you very much for the update skydude
still havent ordered mine yet, but will before season starts here in the NE
Quick Reply: Hayden M6 BT07 primary chain tensioner initial impression
