stealth rack on street glide easy install?
what do you guys think? i heard some difficulty regarding installing other racks for some reason,or maybe the difficulty had to do with passenger backrests? anyway, what have you guys experienced? is it easy to install the stealth rack on a s/g? thanks.
RE: stealth rack on street glide easy install?
The plain chrometube at the rear ofyour fender is removed (two bolts on each side) and the stealth rack installed in its place.To get to the bolts, remove the chrome fender strut covers (two bolts on each side, visible when you remove the saddlebags on each side. HTH.
If you are near a HD store, stop by the parts counter and ask the guy to print out the installation instructions for the stealth rack and see if it is something you want to do--it's a simple installation.
