Ape install-Can I extend throttle by wire
If you don't want to deal with cutting and splicing there are plug and play extensions available for around $40 in just about any length you might need.
http://www.namzcustomcycleproducts.c..._wire_ext.html
Cut the green plug out and make your extensions to be hidden inside the bars. Done it a million times and never an issue. The issue has always came with trying to pull the green plug through the bars only to have it come loose. If you've already pulled the green plug apart then there's a good likelihood of issues with it. They're very fragile.
Spindrifter
05-23-2019 08:50 AM
