Help Speaker Distorting
I would appreciate any advice I can get on this.
I though my front left speaker had blown. I took the fairing apart checked the connection to the speaker and that seemed to fix it. Now it seems to be intermittent, in my experience either a speaker distorts or it doesn’t if the problem is with the speaker, but I'm not an expert either. Have you heard of anything causes this, amp, connections, etc? Do you have any recommendations as to what I can check? I thought it might be my MP3 player but it also does it with the CD player.
I also sent this question to Hogtunes thinking they migth be able to give me some direction on this.
I haven't put the stock speakers back in to test it yet either.
Any help at all would be approeciated
03 Ultra Stock stereo with hogtunes speaks front and back.
Thanks
Thanks
RE: Help Speaker Distorting
Seems like you have a poor speaker connection either at the speaker or along the wire to the radio. You might "squeeze" the female portion of that connection to make sure the "spade" portion inserts in a very tight way.
The Hogtunes are excellent speakers, BTW. Much heavier and larger diameter magnets and they bolt right up in a jiffy. Big difference in sound quality and volume level needed on the road....I'm sorry I didn't replace my stockers earlier.
Good luck....hope this helped.
