04 road king just quit running. HELP
Got out today to ride to do some errands. Bike has been trouble free for 3 yrs that I have owned it. Approaching stop light about 1/4 mile away bike stumbled. Recovered for about another hundred yards did it again. Got to stop light and bike was vibrating bad then shut off. Would not start. Coasted into bank parking lot. Bike will turn over and there is almost a full tank of gas. Fuel pump will come on when key is turned to start. Called progressive towing and got bike towed to house. Put new spark plugs in wires and grounded against heads. No spark at all across electrodes when ignition is turned on and bike is trying to start. Anyone have any ideas? Tried to retrieve any trouble codes but none showed up. Hard for me to believe a relay or coil just died but who knows. Any help would be appreciated.
The output from the kill switch is the input to the starter switch. if the starter is working with the switch the kill switch should be ok.
On Fuel injected models Output from the kill switch turns on system relay and that relay supplies power to the fuel pump circuit.
Have you checked the ignition fuse?
