air ride types
RE: air ride types
ORIGINAL: Puzzled
Were the problems related to the shock length? or the company?
Noooooooo!!!!!![sm=signs006.gif]
You can do a search on this forum for Draggin Baggers and find an earfull. Stick with the companies that know what they are doing. I dought Draggen Baggers has made any advancments since this time last year. They were using Monroe Corvette shocks. If you go this route do some research.
A lot of good people on this sight believed that he (Tony)was doing something cool and backed him by purchasing his kits. He said he would stand behind his product and take care of everyone if they had problems.
Well when the problems started rolling in Tony disappeared. They screwed a lot of people. You got some good advise on some other systems. The Hi-Lo, Legends and so on. Yes these systems do cost more, but they are much better and designed for your application. Please do stay away from last summers Draggin Baggers Drama.
RE: air ride types
I'd still like to know what the actual problems were. Air systems are very basic. From my reading (awhile ago) there was an issue with the tire contacting the fender and the spring rate/ride quality, correct?
Total travel, compressed height, raised height and spring rate needs to be known. Add a good compressor and fittings and off you go.
RE: air ride types
ORIGINAL: Puzzled
RE: air ride types
Ok thank you. Now I got it!
Shock bolt contact is to much raised height travel. I never found this to be an issue in the sense it never bothered me. Some pipes clear and others don't. If one were building a "simple" setup a limiting strap would have to be used if the correct travel length couldn't be achieved via the shock.
Air leaks tend to be end user issues provided the parts used are quality pieces and installed correctly. I recently spent more time on the phone with a gentleman installing his air ride than if I would have installed it for him. In the end it was his desire to install the system without taking his time following through thoroughly.
Ride quality is a tough issue. Everyone likes something different. With air systems they tend to respond to more air better than not enough. Some of the systems out there are air only, I don't care for them. I prefer an air over oil. However the oil lends itself to valving issues and weather it is to firm or to soft.
There is no reason for the lack of customer service. I certainly can see getting overwhelmed with sales than having to deal with issues as a stressful situation. Still no excuse.
The statement above that said "You get what you pay for" is not entirely true. It may apply to the DB debacle but I don't feel a pair of tricked out shocks hidden behind a set of bags is worth $1600. There may be a ton of R&D behind them but dam that is a lot of coin for two shocks and a $125 compressor.
I'd like to see a nice clean looking system that is air over oil for around $600-$700.
RE: air ride types
ORIGINAL: Rocket Jockey
Ultra,
Here is the website: www.airsystemsengineering.com/airfx/index.php
RJ
Ultra,
RJ
