S&S 124LC for Touring
Received 75,088 Likes
can't speak on the 124 but I bought a 120ST motor , took it to Wes at Cycle Rama , had him disassemble the motor and upgrade any parts he thought needed it , re-do the heads ,change the cams etc. and then install and tune the motor , it comes with a 58mm throttle body , it came out to 132hp 138 torque , it gets better mileage than the 103 motor did , runs smoother , has a ton of power and runs cooler too , I think you would see similar results
can's speak on the 124 but I bought a 120ST motor , took it to Wes at Cycle Rama , had him disassemble the motor and upgrade any parts he thought needed it , re-do the heads ,change the cams etc. and then install and tune the motor , it comes with a 58mm throttle body , it came out to 132hp 138 torque , it gets better mileage than the 103 motor did , runs smoother , has a ton of power and runs cooler too , I think you would see similar results
Wes changed the lifters , cams , valve guides , ported heads , welded up intake ports , did a multi angle valve job on intakes , full radius valve job on exit , and other things , I can't remember it all , correction 132 hp 136 torq
Wes put in his Cycle Rama CR-630i cams , I haven't figured out my exact mileage yet , I know it's getting better mileage though because I will fill my tank up and take a 2 1/2 hour ride to a friends, I've done this trip hundreds of times , normally with the 103 when I'd get there I'd just hit reserve , I've done the trip now 3 times on the 120 and when I get there I'm at 1/4 tank
