Champion spark plug # please
RE: Champion spark plug # please
just found this cross reference table and thought i would post it for those that might want to change brands of plugs.
http://www.harley-performance.com/ha...park-plug.html
[align=center][/align]
web link for cross reference.
select power sport not automotive then follow the drop down selections
http://www.sparkplugs.com/
I run Champion RN12Yc in my 93 Tour Glide. Tried the HD 5R6A as recommended in the manual they fouled out the 1st day put the Champs back in and have had no problem. They appear to be the same size ceramic which would indicate the same heat range. might try the BPR5ES-11 to see how they do.
investigate "ion" before switching away from H-D plugs....
It can affect the way your ECM operates based on an 80 volt DC charge the ECM sends down the plug wire between cylinder firings measuring combustion by way of ION content and resistance to ground.
There is a bunch of information regarding this searching this forum....Take the time to read them.
ORIGINAL: twincam47
On my 08' FLHX I will stick with the HD branded plugs basically because of the reason stated above. I may switch out to another brand in the future.....only time will tell.
ORIGINAL: nvsteve
I have used stock and one step colder heat range NGK, Autolite and Champion in 03 and 07 HDs.
Absoluteley no issues with any of them. Take a look at the standard HD plug and compare it to
a Champion. They are the same.
