Lowering Blocks w/Longer Shocks?
I installed 13" Ultra Classic shocks on my 2006 Street Glide to improve the ride for 2-up, fully loaded touring. Very happy. No regrets. However, I do miss the look of the factory lowered rear end, especially with the Tour Pak off.
I'm looking for advice/opinions on this idea: keep the 13" shocks for ride quality, but return the back end to original FLHX height by using those lowering blocks I see all over eBay.
Thoughts?
Thoughts?
Theoretically, if you longer shocks have more travel, and you then lower them, you have the potential to bottom out your tire into your fender. Don't know for sure if that would definitely happen with OEM shocks, but conceptually thats the problem you're running into. That and altering the angle at which the forks are working.
I did that for awhile on my 2009 FLHTC- comparing to 12" shocks, the 13's gave a better ride in terms of comfort- 1" more suspension travel ( 2.75" total) which also means more time for the shocks to move from extension to compression.
however my $26 ebay type blocks felt as if they were moving at the swingarm attachment and pivoting upwards in extension.
I took them off.
when it comes to "looks" my concern is the look thru the windscreen & I'm tall so my feet hit the ground no problem.
the 12" 09+ FLHX shocks gave a more "stable" ride vs blocks but were harsh and jouncy- I have alot of water control dips and speedbumps in my area.
if you change the ride height, don;t forget to adjust your belt
BTW my '95 had white brothers ( now Burly) lowering blocks when i bought it, they were ok but I removed them...my jiffy would drag on lefts
Mike
I took them off.
Mike
